--- title: "system.user.addUser" description: "Adds a new user to a user source." --- # system.user.addUser > Adds a new user to a user source. This function is used in **Python Scripting**. ## Description Adds a new user to a user source. Used in combination with [getNewUser](system-user-getNewUser.md) to create new user. ## Client Permission Restrictions [Permission Type](ignition-modules\vision\vision-project-properties\vision-project-properties.md#vision-permissions-properties): User Management Client access to this scripting function is blocked to users that do not meet the role/zone requirements for the above permission type. This function is unaffected when run in the Gateway scope. ## Syntax `system.user.addUser(userSource, user)` ### Parameters Type | Parameter | Description ------- | ------- | ------ String| `userSource` | The user source to add a user to. If set to an empty string, the function will attempt to use the project's default user source (if called from a project). User| `user` | The user to add, as a [User](https://sdk.inductiveautomation.com/javadoc/ignition83/latest/com/inductiveautomation/ignition/common/user/User.html) object. Refer also to the [PyUser](https://sdk.inductiveautomation.com/javadoc/ignition83/latest/com/inductiveautomation/ignition/common/user/PyUser.html) class. ### Returns **UIResponse** - A [UIResponse](https://sdk.inductiveautomation.com/javadoc/ignition83/latest/com/inductiveautomation/ignition/common/messages/UIResponse.html) object which contains lists of the errors, warnings, and information returned after the add attempt. The contents of the lists are accessible from the getter methods. * `getWarns()` - Returns a list of warning messages that were encountered during the add. * `getErrors()` - Returns a list of error messages that were encountered during the add. * `getInfos()` - Returns a list of "info" messages that were encountered during the add. These messages represent normal logging events that occurred during the add, and can be useful when trying to visualize the events that lead up to a failure. ### Scope Gateway, Vision Client, Perspective Session ## Code Examples ```python title="Example #1" # Get new user. userToGet = system.user.getNewUser("AcmeWest", "mTrejo") # Add some contact info. contactInfo = {"email":"mTrejo@acmewest.com","sms": "5551234"} userToGet.addContactInfo(contactInfo) userToGet.set("password", "thisIsMyPassword") # Adds a user to the the AcmeWest usersource. system.user.addUser("AcmeWest", userToGet) ```
