system.user.addHoliday
Descriptionβ
Allows a holiday to be added.
Permission Type: User Management
Syntaxβ
system.user.addHoliday(holiday)
Parametersβ
| HolidayModel | holiday | The holiday to add, as a HolidayModel object. |
Returnsβ
UIResponse - A UIResponse object with lists of warning, errors and info about the success or failure of the add. The contents of the lists are accessible from the getter methods.
getWarns()- Returns a list of warning messages that were encountered during the add.getErrors()- Returns a list of error messages that were encountered during the add.getInfos()- Returns a list of "info" messages that were encountered during the add.
These messages represent normal logging events that occurred during the add, and can be useful when trying to visualize the events that lead up to a failure.
Scopeβ
Code Examplesβ
Example #1
# This example adds a holiday.
def printResponse(responseList):
if len(responseList) > 0:
for response in responseList:
print "", response
else:
print " None"
from com.inductiveautomation.ignition.common.user.schedule import HolidayModel
from java.util import Date
holidayName = "Groundhog Day"
d = Date(2016 - 1900, 2, 2) # java dates start in 1900
repeatAnnually = False
myHoliday = HolidayModel(holidayName, d, repeatAnnually)
response = system.user.addHoliday(myHoliday)
warnings = response.getWarns()
print "Warnings are:"
printResponse(warnings)
errors = response.getErrors()
print "Errors are:"
printResponse(errors)
infos = response.getInfos()
print "Infos are:"
printResponse(infos)
"""The example above outputs the following:
Warnings are:
None
Errors are:
None
Infos are:
New holiday "Groundhog Day" added.
