--- title: "system.twilio.getActiveCall" description: "Returns a list of configurations for currently active Twilio voice calls." --- # system.twilio.getActiveCall > Returns a list of configurations for currently active Twilio voice calls. This function is used in **Python Scripting**. ## Description Returns a list of configurations for currently active Twilio voice calls. This only applies to synchronous calls that use the reverse-proxy system to call back into Ignition for authentication and alarm acknowledgements. Since calls can last minutes and potentially be stuck ringing for some time, this function gives users a view of the current state of call notifications while they're active. ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.twilio.getActiveCall(accountName)` ### Parameters Type | Parameter | Description ------- | ------- | ------ String| `accountName` | The Twilio account to use for the calls. ### Returns **CallView** - An array of [CallView](https://javadoc.io/doc/com.twilio.sdk/twilio/0.0.1/com/twilio/rest/api/v2010/account/Call.html) objects, including the properties listed below. |Property| Description| Type| |--|--|--| |sid| The unique ID generated by Twilio representing the call.|String | |answeredBy| Whether the call was answered by a human or a machine.|String | |status| Current call [status](https://javadoc.io/doc/com.twilio.sdk/twilio/0.0.1/com/twilio/rest/api/v2010/account/Call.Status.html), options include BUSY, CANCELED, COMPLETED, FAILED, IN_PROGRESS, NO_ANSWER, QUEUED, and RINGING.|String| |apiVersion| API version used to create the call.|String| |callerName| The caller's name, if Caller ID is enabled.| String| |duration| The duration of the call.|String| |from| The phone number configured with Twilio to use for making the calls.|String| |to| The phone number of the recipient.|String| |queueTimeString| The call queue time.|String| |dateCreatedString| The call creation date, formatted as a `org.joda.time.DateTime` object.| String| |dateUpdatedString| The call updated date, formatted as a `org.joda.time.DateTime` object.|String| |endTimeString| The call end time, formatted as a `org.joda.time.DateTime` object.|String| |startTimeString| The call start time, formatted as a `org.joda.time.DateTime` object.|String| |dateCreated| The call creation date.|Long| |dateUpdated| The call updated date.|Long| |endTime| The call end time.|Long| |startTime| The call start time.|Long | ### Scope Gateway, Vision Client, Perspective Session
