--- title: "system.tag.writeAsync" description: "Asynchronously writes values to tags at specified paths." --- # system.tag.writeAsync > Asynchronously writes values to tags at specified paths. This function is used in **Python Scripting**. ## Description Asynchronously writes values to tags at specified paths. The script will not wait for the write operation to complete before moving on, but you can provide a callback function to run further code after the write has finished. For a blocking tag write operation, see [system.tag.writeBlocking](appendix\scripting-functions\system-tag\system-tag-writeBlocking.md). ## Client Permission Restrictions [Permission Type](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties): Tag Editing Client access to this scripting function is blocked to users that do not meet the role/zone requirements for the above permission type. This function is unaffected when run in the Gateway scope. ## Syntax `system.tag.writeAsync(tagPaths, values, [callback])` ### Parameters Type | Parameter | Description ------- | ------- | ------ List| `tagPaths` | A List of tag paths to write to. A tag property can be included in the path. If no property is specified in a tag path, the Value property is assumed. List| `values` | The values to write to the specified paths. Callable| `callback` | A function that will be invoked after the write operation is complete. The function must take a single argument: a List of [QualityCode](appendix\reference-pages\scripting-object-reference\scripting-object-reference.md#qualitycode) objects corresponding to the results of the write operation. [optional] ### Returns Nothing ### Scope Gateway, Vision Client, Perspective Session ## Code Examples ```python title="Example #1 - Write to Multiple Tags" paths = ["[default]Tag1", "[default]Folder/Tag2"] values = [10, 10] system.tag.writeAsync(paths, values) ``` ```python title="Example #2 - Using a Callback Function" paths = ["[default]Tag1", "[default]Folder/Tag2"] values = [10, 10] def myCallback(asyncReturn): for result in asyncReturn: # Do something if a bad qualified value was returned if not result.good: print result system.tag.writeAsync(paths, values, myCallback) ```
