--- title: "system.sfc.startChart" description: "Starts a new instance of a chart." --- # system.sfc.startChart > Starts a new instance of a chart. This function is used in **Python Scripting**. ## Description Starts a new instance of a chart. The chart must be set to "Callable" execution mode. ## Client Permission Restrictions [Permission Type](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties): SFC Management Client access to this scripting function is blocked to users that do not meet the role/zone requirements for the above permission type. This function is unaffected when run in the Gateway scope. ## Syntax `system.sfc.startChart(projectName, chartPath, parameters)` ### Parameters | Type | Parameter | Description | |-------|-------|------| | String | `projectName` | The name of the project that the chart was created in. The project that this function is called in will be used if no name is provided, or if the function is called from outside a project, the default Gateway project name will be used. | | String | `chartPath` | The path to the chart, for example "ChartFolder/ChartName". | | Dictionary[String, Any] | `parameters` | A dictionary of arguments. Each key-value pair in the dictionary becomes a variable in the chart scope and will override any default. | ### Returns **String** - The unique ID of this chart. ### Scope Gateway, Vision Client, Perspective Session ## Code Examples ```python title="Code Snippet" # The following will start an SFC with a dictionary of values to use inside the chart args= {"var1":10, "Var2":15,"Var3":1} path = "ChartFolder/ChartName" sfcID = system.sfc.startChart(path, args) ```
