--- title: "system.sfc.setVariable" description: "Sets a variable inside a currently running chart." --- # system.sfc.setVariable > Sets a variable inside a currently running chart. This function is used in **Python Scripting**. ## Description Sets a variable inside a currently running [SFC chart](../../../ignition-modules/sequential-function-charts/SFC-basics/SFC-basics.md). ## Client Permission Restrictions [Permission Type](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties): SFC Management Client access to this scripting function is blocked to users that do not meet the role/zone requirements for the above permission type. This function is unaffected when run in the Gateway scope. ## Syntax `system.sfc.setVariable(instanceId, [stepId], variableName, variableValue)` ### Parameters Type | Parameter | Description ------- | ------- | ------ String| `instanceId` | The instance identifier of the chart. String| `stepId` | The id for a step inside of a chart. If omitted the function will target a chart scoped variable. [optional] String| `variableName` | The name of the variable to set. Object| `variableValue` | The value for the variable to be set to. ### Returns Nothing ### Scope Gateway, Vision Client, Perspective Session :::note Omitting the **stepId** parameter will cause the function to target a chart scoped variable. If the variable is persistent to the whole chart, or used in multiple different steps, then this parameter should be omitted. If a stepId parameter is used, then the function will target a step scoped variable. The step associated with the stepId must be the currently active step. ::: ## Code Examples ```python title="Code Snippet" # The following passes the chart instance ID and step ID to a client message Handler. The message handler can then wait # for user input, and then write back to the step variables. # The example assumes there is a chart scoped variable called confirmEndchart, and a step scoped variable called "messageSent". # Get the instanceId of the current chart chartID = chart.get("instanceId") # Get the id of the step stepID = step.get("id") # Create a payload to pass to the client. # Include the instanceId and stepId so the script from the message handler knows which # chart and step to write to payload = {"chartID" : chartID, "stepID" : stepID} # Send the message system.util.sendMessage(project="SFC", messageHandler="SFCMessage", payload=payload) ############ # The following script would be placed on a client message handler. This receives the payload, # and sets a variable on either the chart or step depending on user selection # Read items out of the payload id = payload['chartID'] stepId = payload['stepID'] # Ask the user to end the chart if system.vision.showConfirm("Would you like to end the process"): #If yes, end the chart. confirmEndChart is chart scoped, so only 3 parameters are passed system.sfc.setVariable(id, "confirmEndChart", True) else: #If no, reset the step.messageSent variable so that the user will be prompted again #messageSent is step scoped, so 4 parameters are passed system.sfc.setVariable(id, stepId, "messageSent", False) ```
