--- title: "system.sfc.redundantCheckpoint" description: "Synchronizes chart and step variables of the specified chart instance across a redundant cluster." --- # system.sfc.redundantCheckpoint > Synchronizes chart and step variables of the specified chart instance across a redundant cluster. This function is used in **Python Scripting**. ## Description Synchronizes chart and step variables of the specified chart instance across a redundant cluster, allowing the chart instance to continue where it left off if a redundant failover occurs. Check out [redundancy sync](ignition-modules\sequential-function-charts\SFC-basics\chart-properties.md#redundancy-sync) for more information. ## Client Permission Restrictions [Permission Type](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties): SFC Management Client access to this scripting function is blocked to users that do not meet the role/zone requirements for the above permission type. This function is unaffected when run in the Gateway scope. ## Syntax `system.sfc.redundantCheckpoint(instanceId)` ### Parameters Type | Parameter | Description ------- | ------- | ------ String | `instanceId` | The instance identifier of the chart. ### Returns Nothing ### Scope Gateway, Vision Client, Perspective Session ## Code Examples ```python title="Code Snippet" # This example will create a redundant checkpoint in case the primary Gateway in the redundant pair fails. instanceId = "The ID of the chart you want to synchronize across the redundant pair" system.sfc.redundantCheckpoint(instanceId) ```
