system.serial.readLine
Descriptionβ
Attempts to read a line from a serial port. A "line" is considered to be terminated by either a line feed ('\n'), a carriage return ('\r'), or a carriage return followed immediately by a line feed.
The function will wait until the timeout period for a terminator. If the timeout is reached before the line is properly terminated, then the buffer will be dumped, possibly resulting in data loss.
Syntaxβ
system.serial.readLine(port [, timeout] [, encoding])
Parametersβ
| String | port | The previously configured serial port to use. |
| Integer | timeout | Maximum amount of time, in milliseconds, to block before returning. Default is 5000. [optional] |
| String | encoding | The String encoding to use. Default is UTF8. [optional] |
Returnsβ
String - A line of text.
Scopeβ
Code Exampleβ
Code Snippet
# This example will read from the "COM1" port and set the timeout to 10000 milliseconds.
port = "COM1"
timeout = 10000
system.serial.readLine(port,timeout)
