Version: 8.3
system.serial.openSerialPort
Opens a previously configured serial port for use. Will throw an exception if the serial port cannot be opened.
system.serial.openSerialPort(port)
StringportThe name of the serial port, e.g., "COM1" or "dev/ttyS0".
Nothing
Code Snippet - Using a Literal Value
# This example will open a port called "COM1"
system.serial.openSerialPort("COM1")
Code Snippet - Using a Variable
# This example will open a port using a variable called port that has a value of "COM1"
port = "COM1"
