--- title: "system.security.getUserRoles" description: "Fetches the roles for a user from the Gateway." --- # system.security.getUserRoles > Fetches the roles for a user from the Gateway. This function is used in **Python Scripting**. ## Description Fetches the roles for a user from the Gateway. This may not be the currently logged in user. Requires the password for that user. If the authentication profile name is omitted, then the current project's default authentication profile is used. ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax - Vision `system.security.getUserRoles(username, password, [authProfile], [timeout])` ### Parameters Type | Parameter | Description ------- | ------- | ------ String| `username` | The username to fetch roles for String| `password` | The password for the user String| `authProfile` | The name of the authentication profile to run against. Optional. Leaving this out will use the project's default profile. [optional] Integer| `timeout` | Timeout for client-to-gateway communication. Default is 60,000ms. [optional] ### Returns **Tuple** - A list of the roles that this user has, if the user authenticates successfully. Otherwise, returns None. ### Scope Vision Client ## Syntax - Gateway and Perspective `system.security.getUserRoles(username, password, [authProfile])` ### Parameters Type | Parameter | Description ------- | ------- | ------ String| `username` | The username to fetch roles for. String| `password` | The password for the user. String| `authProfile` | The name of the authentication profile to run against. Leaving this out will use the project's default profile. [optional] ### Returns **Tuple** - A list of the roles that this user has, if the user authenticates successfully. Otherwise, returns None. ### Scope Gateway, Perspective Session ## Code Examples ```python title="Example #1" # Fetch the roles for a given user, and check to see if the role "Admin" is in them. reqRole = "Admin" username = "Billy" password= "Secret" roles = system.security.getUserRoles(username, password) if reqRole in roles: # do something requiring "Admin" role. ```
