--- title: "system.secsgem.copyEquipment" description: "Creates a copy of an equipment connection." --- # system.secsgem.copyEquipment > Creates a copy of an equipment connection. This function is used in **Python Scripting**. ## Description Creates a copy of an equipment connection and places it in the Gateway > Config > SECS/GEM > Equipment. Common settings can be overridden for the new connection. An exception is thrown if the new equipment connection cannot be created. ## Client Permission Restrictions [Permission Type](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties): SECS/GEM Management Client access to this scripting function is blocked to users that do not meet the role/zone requirements for the above permission type. This function is unaffected when called in the Gateway scope. ## Syntax :::tip This function accepts [keyword arguments](platform\scripting\python-scripting\user-defined-functions.md#keyword-arguments). ::: `system.secsgem.copyEquipment( equipmentSource, newEquipmentName, enabled, activeAddress, activePort, passiveAddress, passivePort, deviceId [, dbTablePrefix] [,description])` ### Parameters Type | Parameter | Description ------- | ------- | ------ String| `equipmentSource` | Some new equipment settings will be retrieved from this equipment connection. Specify the source equipment connection name. String| `newEquipmentName` | The name of the new equipment connection. Boolean| `enabled` | If set to false, the new equipment connection will be disabled after it is created. String| `activeAddress` | IP Address of new equipment. Must be specified if the SECS/GEM module is used in Active mode. Otherwise, do not use this parameter. Integer| `activePort` | Port number of new equipment. Must be specified if the SECS/GEM module is used in Active mode. Otherwise, do not use this parameter. String| `passiveAddress` | IP Address of new equipment. Must be specified if the SECS/GEM module is used in Passive mode. Otherwise, do not use this parameter. Integer| `passivePort` | Port number of new equipment. Must be specified if the SECS/GEM module is used in Passive mode. Otherwise, do not use this parameter. Integer| `deviceId` | Unique identifier of new equipment. This value must be an integer, and is specified within the equipment. String| `dbTablePrefix` | SECS/GEM database table names will use the specified prefix for the new equipment connection. If no prefix is specified, the description of the source equipment will be used. Optional. String| `description` | The description for the new equipment connection. If no description is specified, the description of the source equipment will be used. Optional. ### Returns Nothing ### Scope Vision Client ## Address and Port Parameters When calling this function, only one set of address and port parameters need to be specified: Either **activeAddress** and **activePort**, or **passiveAddress** and **passivePort**. Optionally, both sets of parameters may be specified, but the function will throw an exception if neither are specified. ## Code Examples ```python title="Code Snippet - Copy Equipment" system.secsgem.copyEquipment(equipmentSource="ToolOne", newEquipmentName="ToolTwo", enabled=True, activeAddress="192.168.1.5", activePort=15500, deviceId=0) ```
