--- title: "system.secrets.readSecretValue" description: "Reads the plaintext value of a secret." --- # system.secrets.readSecretValue > Reads the plaintext value of a secret. This function is used in **Python Scripting**. ## Description Reads the plaintext value of a secret given the name of the Secret Provider and the name of the secret. The PyPlaintext class contains a secret and performs much the same as the Java class Plaintext. To manage the lifecycle of the secret, returned as a PyPlaintext, either call the `clear()` method when finished or use a `with...as` statement to automatically clear the PyPlaintext. Note that the `system.secret.readSecretValue` system function and PyPlaintext are not threadsafe. ## Syntax `system.secrets.readSecretValue(providerName, secretName)` ### Parameters |Type | Parameter | Description | |------- | ------- | ------| |String| `providerName` | The name of the Secret Provider to read the secret from.| |List| `secretName` | The name of the secret to read.| ### Returns A PyPlaintext instance that contains the secret. ### Scope Gateway, Vision Client, Perspective Session ## PyPlaintext Class It is important to remember to clear the PyPlaintext instance after you are done accessing the secret. The preferred way to do so is use the Python `with...as` statement, as it is an efficient way to manage resource teardown. If the `with...as` statement is not appropriate for your use-case, you must clear the PyPlaintext instance manually using the `clear()` method. * When using the `getSecretAsString()` methods, the returned string representing the secret is not cleaned up until garbage collection reclaims the memory. * When using the `getSecretAsBytes()` method, the byte array returned is a direct reference to the bytes stored in the PyPlaintext instance. Therefore the array returned is cleared when the PyPlaintext is cleared. Refer to the **Decode Returned Java Compatible Bytes** code example below for options on what to do when the pyPlaintext instance is returned with `getSecretAsBytes`. ## Code Examples ```python title="Code Snippet using a with...as Statement" with system.secrets.readSecretValue("InternalProvider1", "secret01") as plaintext: useSecret(plaintext.getSecretAsString()) ``` ```python title="Code Snippet using the clear() Method" pyPlaintext = system.secrets.readSecretValue(provName, secretName) # The original secret is returned by calling methods on the returned PyPlaintext object. byteArray = pyPlaintext.getSecretAsBytes() asString = pyPlaintext.getSecretAsString() # When done using PyPlaintext, call the clear() method. pyPlaintext.clear() ``` ```python title="Decode Returned Java Compatible Bytes" # The following two examples show how to decode the Java compatible bytes # Returned from getSecretAsBytes(). byteArray = pyPlaintext.getSecretAsBytes() # Option 1: Use Java String to decode to a string. from java.lang import String stringDecoded = str(String(byteArray, "UTF-8")) # Options 2: Convert to python byteArray and decode to a string. pyByte = bytearray(byteArraySecret) stringDecoded = pyByte.decode("UTF-8") ```
