--- title: "system.secrets.readConfiguredSecretValue" description: "Reads the value of a secret." --- # system.secrets.readConfiguredSecretValue > Reads the value of a secret. This function is used in **Python Scripting**. ## Description Reads the value of a secret configured by its SecretConfig. ## Syntax `system.secrets.readConfiguredSecretValue(secretConfig)` ### Parameters | Type | Parameter | Description | |---|---|---| | PyObject | secretConfig | The JSON object containing the SecretConfig. | ### Returns **PyPlaintext** - A PyPlaintext instance containing the specified secret. ### Raises **ValueError** - Throws a ValueError if there is no JSON. **SecretException** - Throws a SecretException if there is a problem reading the secret. **JsonParseException** - Throws a JsonParseException if there is a problem parsing the SecretConfig from the given argument. ### Scope Gateway, Vision Client, Perspective Session ## Code Examples ```python title="Code Snippet" # This example will create an embedded secret that an operator can use and prints it to # a label component on the same view. # Create the embedded secret cipher = system.secrets.encrypt('password') embeddedSecret = system.secrets.createEmbeddedSecretConfig(cipher) # Print it to a label component self.getSibling("Label").props.text = system.secrets.readConfiguredSecretValue(embeddedSecret).getSecretAsString() ```
