--- title: "system.secrets.encrypt" description: "Encrypts data using the Secrets Management system encryption service." --- # system.secrets.encrypt > Encrypts data using the Secrets Management system encryption service. This function is used in **Python Scripting**. ## Description Encrypts supplied data using the Secrets Management system encryption service and returns a JSON object containing the encrypted secret. ## Syntax #1 `system.secrets.encrypt(string, [charset])` ### Parameters |Type | Parameter | Description | |------- | ------- | ------| |String| `string` | The string data to encrypt.| |String| `charset` | The charset to use when encrypting. Defaults to UTF-8. [optional]| ### Returns A PyDictionary containing the encrypted secret or None if the JSON is empty. The PyDictionary includes keys such as `ciphertext`, `encrypted_key`, `iv`, `protected`, and `tag`. ### Scope Gateway, Vision Client, Perspective Session ## Syntax #2 `system.secrets.encrypt(bytes)` ### Parameters |Type | Parameter | Description | |------- | ------- | ------| |List| `bytes` | The byte[] data to encrypt. Use a Java compatible byte array for encrypting bytes.| ### Returns A PyDictionary containing the encrypted secret or None if the JSON is empty. The PyDictionary includes keys such as `ciphertext`, `encrypted_key`, `iv`, `protected`, and `tag`. ### Scope Gateway, Vision Client, Perspective Session ## Code Examples ```python title="Syntax #1 Code Snippet" # Encrypt with UTF-8 charset encrypted = system.secrets.encrypt(stringText) # Encrypt with a custom charset encrypted = system.secrets.encrypt(stringText, "UTF-16") ``` ```python title="Syntax #2 Code Snippet" # Identify content that needs to be encoded. stringText = "someTextToEncrypt" charset = "UTF-8" # Encode Java/jython compatible bytes for encryption. # The following are two examples of how to create compatible bytes. # Option 1: Use Java String from java.lang import String j_bytes = String(stringText).getBytes(charset) # Option 2: Use JArray (Java Arrays in Jython) j_bytes = jarray.array(stringText.encode(charset), "b") # Encrypt the byte result from one of the two options above. encrypted = system.secrets.encrypt(j_bytes) ```
