--- title: "system.secrets.createReferencedSecretConfig" description: "Creates a new Referenced SecretConfig instance." --- # system.secrets.createReferencedSecretConfig > Creates a new Referenced SecretConfig instance. This function is used in **Python Scripting**. ## Description Creates a new Referenced SecretConfig instance given the name of the secret provider and the name of the secret stored in the provider. ## Syntax `system.secrets.createReferencedSecretConfig(providerName, secretName)` ### Parameters | Type | Parameter | Description | |---|---|---| | String | providerName | The name of the secret provider. | | String | secretName | The name of the secret. | ### Returns **PyObject** - A Dictionary containing the JSON representation of a Referenced SecretConfig instance with the provider and secret names. ### Raises **ValueError** - Throws a ValueError if the providerName or secretName parameters do not have any values. ### Scope Gateway, Vision Client, Perspective Session ## Code Examples ```python title="Code Snippet" # This example will take a user-specified secret and use it as a referenced password # in the creation of an S7-1200 device using the Siemens Enhanced driver. # Set the referenced secret myProviderName = "mySecrets" mySecretName = "coolSecret" referencedConfig = system.secrets.createReferencedSecretConfig(myProviderName, mySecretName) # Create the Siemens device with our referenced password system.device.addDevice( deviceType='com.inductiveautomation.ignition.siemens', deviceName='siemensEnhanced', deviceProps={ 'hostname': '0.0.0.0', 'deviceType': 'S7_1200', 'password': referencedConfig } ) ```
