--- title: "system.secrets.createEmbeddedSecretConfig" description: "Creates a new Embedded SecretConfig instance." --- # system.secrets.createEmbeddedSecretConfig > Creates a new Embedded SecretConfig instance. This function is used in **Python Scripting**. ## Description Creates a new Embedded SecretConfig instance given the JSON representation of the encrypted data. ## Syntax `system.secrets.createEmbeddedSecretConfig(json)` ### Parameters | Type | Parameter | Description | |---|---|---| | PyObject | json | The JSON object containing the encrypted secret. | ### Returns **PyOjbect** - A Dictionary containing the JSON representation of an Embedded SecretConfig instance containing the encrypted secret. ### Raises **ValueError** - Throws a ValueError if there is no JSON. ### Scope Gateway, Vision Client, Perspective Session ## Code Examples ```python title="Code Snippet" # This example will take a user-specified secret and use it as an embedded password # in the creation of an S7-1200 device using the Siemens Enhanced driver. # Set the embedded secret cipher = system.secrets.encrypt('myPassword') embeddedConfig = system.secrets.createEmbeddedSecretConfig(cipher) # Create the Siemens device with our embedded password system.device.addDevice( deviceType='com.inductiveautomation.ignition.siemens', deviceName='siemensEnhanced', deviceProps={ 'hostname': '0.0.0.0', 'deviceType': 'S7_1200', 'password': embeddedConfig } ) ```
