Version: 8.3
system.report.getReportNamesAsDataset
Gets a data of all reports for a project. Throws an IllegalArgumentException when any of the following occurs: If the project name is omitted in the Gateway scope, project does not exist.
note
system.report.getReportNamesAsDataset([ project], [includeReportName])
StringprojectThe name of the project where the reports are located. Optional in client scope.
BooleanincludeReportNameWhen set to False, the end of Path does not include the report name. Default is True. [optional]
Dataset - A dataset of report paths and names for the project. Returns an empty dataset if the project has no reports.
Code Snippet
# Gets a dataset of reports for the current project and displays
# them in a Tree View component.
event.source.parent.getComponent('Tree View').data = system.report.getReportNamesAsDataset()
