--- title: "system.project.requestScan" description: "Requests a manual scan of the projects directory in order to refresh projects and their resources." --- # system.project.requestScan > Requests a manual scan of the projects directory in order to refresh projects and their resources. This function is used in **Python Scripting**. ## Description Requests a manual scan of the projects directory in order to refresh projects and their resources. If a scan is currently running, this method has no effect and will return when the in-progress scan has finished. This function blocks the current thread until a scan has completed. ## Client Permission Restrictions This scripting function has no [Client Permission](ignition-modules\vision\vision-project-properties\vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.project.requestScan([timeout])` ### Parameters Type | Parameter | Description ------- | ------- | ------ Integer | `timeout` | The amount of time, in seconds, to block the current thread before timing out. Default is 10 seconds. [optional] ### Returns None ### Scope Gateway, Perspective Session ## Code Example ```python title="Code Snippet" # This example requests a manual scan of the project directory # while blocking the current thread for 30 seconds before timing out. system.project.requestScan(30) ```
