Version: 8.3
system.perspective.refresh
Triggers a refresh of the page.
note
This method should not be confused with the refreshBinding component method, which automatically fires a binding on a Perspective component property.
``system.perspective.refresh([sessionId], [pageId])
StringsessionIdIdentifier of the Session to target. If omitted, the current Session will be used automatically. When targeting a different session, then the pageId parameter must be included in the call. [optional]
StringpageIdIdentifier of the page to target. If omitted, the current Page will be used automatically. [optional]
Nothing
Gateway, Perspective Session
note
This function will only work in the Gateway scope if both sessionId and pageId are supplied to the call.
Code Snippet
# This example will refresh the current Perspective page.
system.perspective.refresh()
