Version: 8.3
system.perspective.download
Downloads data from the Gateway to a device running a Session. When calling from the Gateway scope, the call must include a sessionId.
This function interacts with mobile apps directly to ensure that download requests can be saved to the local device. Requires version 1.0.2 of the Ignition Perspective App.
Syntax - Gateway Scope​
tip
system.perspective.download(filename, data, [contentType], sessionId, [pageId])
StringfilenameSuggested name for the downloaded file.
StringdataThe data to be downloaded. May be a string, a byte[], or an InputStream. Strings will be written in UTF-8 encoding.
StringcontentTypeValue for the "Content-Type" header, for example: "text/plain; charset=utf-8". [optional]
StringsessionIdIdentifier of the Session to target. If omitted, the current Session will be used automatically. When targeting a different session, then the pageId parameter must be included in the call.
StringpageIdIdentifier of the page to target. If omitted, the current page will be used automatically. [optional]
Nothing
Gateway, Perspective Session
note
This function will only work in the Gateway scope if both sessionId and pageId are supplied to the call.
Syntax - Session Scope​
tip
system.perspective.download(filename, data, [contentType], [sessionId], [pageId])
StringsessionIdIdentifier of the Session to target. If omitted, the current Session will be used automatically. When targeting a different session, then the pageId parameter must be included in the call. [optional]
Nothing
Perspective Session
Code Snippet
# Downloads the file "myFile.pdf" (located on the Gateway) to the user running the current Session.
filename = 'myFile.pdf'
data = system.file.readFileAsBytes('C:\\'+filename)
system.perspective.download(filename, data)
