Version: 8.3
system.perspective.closePopup
Closes a popup view.
tip
system.perspective.closePopup(id, [sessionId], [pageId])
StringidThe unique identifier for the popup, given to the popup when first opened. If given an empty string, then the most recently focused popup will be closed.
StringsessionIdIdentifier of the Session to target. If omitted, the current Session will be used automatically. When targeting a different session, then the pageId parameter must be included in the call. [optional]
StringpageIdIdentifier of the page to target. If omitted, the current Page will be used automatically. [optional]
Nothing
Gateway, Perspective Session
note
This function will only work in the Gateway scope if both sessionId and pageId are supplied to the call.
Code Snippet
# Closes the popup with the given id.
system.perspective.closePopup('popup 4')
Code Snippet
# Closes the last focused popup
system.perspective.closePopup('')
