--- title: "system.opcua.removeConnection" description: "Removes an OPC UA Connection." --- # system.opcua.removeConnection > Removes an OPC UA Connection. This function is used in **Python Scripting**. ## Description ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.opcua.removeConnection(name)` ### Parameters Type | Parameter | Description ------- | ------- | ------ String | `name` | The name of the OPC UA connection to remove. ### Returns **Boolean** - A boolean value representing whether the function was able to remove the connection. Returns True if the connection was successfully removed. Returns False if the connection was not removed. ### Scope Gateway, Perspective Session
