--- title: "system.opcua.callMethod" description: "Calls a method in an OPC UA server." --- # system.opcua.callMethod > Calls a method in an OPC UA server. This function is used in **Python Scripting**. ## Description Calls a method in an OPC UA server. To make the most of this function, you'll need to be familiar with methods in the [OPC UA server](ignition-modules\opc-ua\opc-ua-connections\opc-ua-connections.md). ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.opcua.callMethod(connectionName, objectId, methodId, inputs)` ### Parameters Type | Parameter | Description ------- | ------- | ------ String| `connectionName` | The name of the OPC UA connection to the server that the method resides in. String| `objectId` | The NodeId of the Object Node the Method is a member of. String| `methodId` | The NodeId of the Method Node to call. List| `inputs` | A list of input values expected by the method. ### Returns **Tuple** - A tuple containing the following: - 0 Resulting StatusCode for the call - 1 A list of StatusCode objects corresponding to each input argument - 2 A list of output values. ### Scope Gateway, Perspective Session ### The StatusCode Object This function returns multiple StatusCode objects. StatusCode is a tuple, containing the following: |Index Order|Description| |--|--| |0| The value of the code| |1 |The name of the code| |2|A description of the code| ## Code Examples ```python title="Example #1" # Call the Server object's GetMonitoredItems method. result = system.opcua.callMethod( "Ignition OPC UA Server", "ns=0;i=2253", "ns=0;i=11492", [1] ) # Below we print the various elements in the results. The print statements could easily be replaced by something more useful. # Prints the StatusCode for the call. print result[0] # Prints the list of StatusCodes, one for each input argument passed to system.opcua.callMethod. print result[1] # Prints the output values from the call. print result[2] ```
