Version: 8.3
system.opchda.readProcessed
Reads processed values from the OPC-HDA server. Processed values are calculated values, based on the aggregate function requested for each item. The list of aggregates can be obtained by calling system.opchda.getAggregates().
system.opchda.readProcessed(serverName, itemIds, startDate, endDate, resampleIntervalMS, aggregates)
StringserverNameThe name of the defined OPC-HDA server to read.
List[String]itemIdsA list of item ids to read.
AnystartDateThe starting date/time of the query.
AnyendDateThe ending date/time of the query.
IntegerresampleIntervalMSThe interval, in milliseconds, that each value should cover.
List[Integer]aggregatesA list which should be one-to-one with the item ids requested, specifying the integer id of the aggregation function to use. The aggregation ids are defined in the OPC-HDA specification. The list of aggregates can also be obtained by calling system.opchda.getAggregates().
List[ReadResults] - A list of read results which is one-to-one with the item IDs passed in. The ReadResult object has a 'serviceResult' quality property that indicates whether the call was successful, and is itself a list of QualifiedValues.
Example #1
# This example will read processed data from a Matrikon server between two specified dates.
# Declare start and end dates
start = system.date.getDate(2022, 3, 14)
end = system.date.now()
# Call system function and print results
readValue = system.opchda.readProcessed("Matrikon",[1],start,end,1000,[1])
print readValue
