Version: 8.3
system.opchda.insert
Insert values on the OPC-HDA server.
Permission Type: OPC Server Management
system.opchda.insert(serverName, itemId, value, date, quality)
StringserverNameThe name of the defined OPC-HDA server.
StringitemIdThe item ID to perform the operation on.
AnyvalueThe value to insert.
AnydateThe date to insert.
IntegerqualityThe quality to insert.
QualityCode - The result of the insert. See Scripting Object Reference.
Example #1
# This will insert the value for May 28th, 2014 at 5:42:33.
date = system.date.getDate(2014, 4, 28)
datetime = system.date.setTime(date, 5, 42, 33)
system.opchda.insert("MyHistoryServer", "MyItemId", 42.5, datetime, 192)
