Version: 8.3
system.opchda.getAttributes
Queries the given server for the item attributes that are available with system.opchda.readAttributes().
system.opchda.getAttributes(serverName)
StringserverNameThe name of the defined OPC-HDA server to query.
List[AttributeInfo] - A list of AttributeInfo objects. See the AttributeInfo Methods panel for a listing of available methods.
AttributeInfo Methods​
MethodDescriptionReturn Type
getId()Returns the ID of the attribute.Integer
getName()Returns the name of the attribute.String
getDesc()Returns the description of the attribute.String
getType()Returns the data type of the attribute.Datatype
Code Snippet
# This example gets the description of a Matrikon OPC HDA explorer
# Declare a OPC HDA variable using the system function and prints out the results
opcHda = system.opchda.getAttributes('Matrikon HDA')
print opcHda
# Use the getDesc() method to get the description of the attribute and print out the result
getDesc = hda[1].getDesc()
print getDesc
