--- title: "system.opchda.browse" description: "Performs a browse at the given root." --- # system.opchda.browse > Performs a browse at the given root. This function is used in **Python Scripting**. ## Description ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.opchda.browse(root)` ### Parameters Type | Parameter | Description ------- | ------- | ------ String | `root` | The root at which to browse. Needs to be a qualified path. ### Returns **BrowseResults**[] - The results of the browse operation from the given root. Refer to the [Results](https://sdk.inductiveautomation.com/javadoc/ignition83/latest/com/inductiveautomation/ignition/common/browsing/Results.html) object in the SDK. ### Scope Gateway, Vision Client, Perspective Session
