--- title: "system.opc.writeValues" description: "This function is a bulk version of system.opc.writeValue." --- # system.opc.writeValues > This function is a bulk version of system.opc.writeValue. This function is used in **Python Scripting**. ## Description This function is a bulk version of [system.opc.writeValue](system-opc-writeValue.md). It takes a list of addresses and a list of objects, which must be the same length. It will write the corresponding object to the corresponding address in bulk. It will return a list of status codes representing the individual write success or failure for each corresponding address. ## Client Permission Restrictions [Permission Type](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties): OPC Server Management Client access to this scripting function is blocked to users that do not meet the role/zone requirements for the above permission type. This function is unaffected when run in the Gateway scope. ## Syntax `system.opc.writeValues(opcServer, itemPaths, values)` ### Parameters Type | Parameter | Description ------- | ------- | ------ String| `opcServer` | The name of the OPC server connection in which the items reside. List[String]| `itemPaths` | A list of item paths, or addresses, to write to. List[Any]| `values` | A list of values to write to each address specified. ### Returns **List[Quality]** - An array of Quality objects, each entry corresponding in order to the addresses specified. Refer to the list of [writeValues](https://sdk.inductiveautomation.com/javadoc/ignition83/latest/com/inductiveautomation/ignition/common/script/builtin/AbstractOPCUtilities.html#writeValue(org.python.core.PyObject[],java.lang.String[])) objects. ### Scope Gateway, Vision Client, Perspective Session ## Code Examples ```python title="Code Snippet" # This example will write values to specified OPC items # Declare a list of values objectValue = [3] # Declare the item path to write values back to itemPath = "ns=1;s=[GoldSim]B3/B3:100" # Write the values to the specified item. Replace "Ignition OPC UA Server" with your chosen OPC UA server. system.opc.writeValues("Ignition OPC UA Server", itemPath, objectValue) ```
