system.opc.isServerEnabled
Descriptionβ
Checks if an OPC server connection is enabled or disabled.
Syntaxβ
system.opc.isServerEnabled(serverName)
Parametersβ
| String | serverName | The name of an OPC server connection. |
Returnsβ
Boolean - True if the connection is enabled, false if the connection is disabled
Scopeβ
Code Examplesβ
Code Snippet
# The following will iterate through all configured OPC servers, and check if they are enabled or disabled
# This code interacts in the client scope, so it should be placed on a component, such as a Button.
# Retrieve a list of all servers in the gateway
allServers = system.opc.getServers()
# Initialize a message. The example will append the state of each server to this message.
# The "\n" at the end of the string adds a new line
message = "Server Status:\n"
# Iterate through each server.
for server in allServers:
# For each server, append the server name, a colon, the state of the server, and a new line.
# isServerEnabled returns a boolean, but may use the string format specifier (%s)
message += "%s : %s \n" % (server, system.opc.isServerEnabled(server))
# Show the state of the servers in a message box.
system.vision.showMessage(message)
