--- title: "system.opc.getServerState" description: "Retrieves the current state of the given OPC server connection." --- # system.opc.getServerState > Retrieves the current state of the given OPC server connection. This function is used in **Python Scripting**. ## Description Retrieves the current state of the given OPC server connection. If the given server is not found, the return value will be None. Otherwise, the return value will be one of these strings: - UNKNOWN - FAULTED - CONNECTING - CLOSED - CONNECTED - DISABLED ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.opc.getServerState(opcServer)` ### Parameters Type | Parameter | Description ------- | ------- | ------ String | `opcServer` | The name of an OPC server connection. ### Returns **String** - A string representing the current state of the connection, or None if the connection doesn't exist. ### Scope Gateway, Vision Client, Perspective Session ## Code Examples ```python title="Code Snippet" # The following will check the state of all configured servers, and show them in a message box. # This code interacts in the client scope, so it should be placed on a component, such as a Button. # Retrieve a list of all servers in the gateway allServers = system.opc.getServers() # Initialize a message. The example will append the state of each server to this message. # The "\n" at the end of the string adds a new line message = "Server State:\n" # Iterate through each server. for server in allServers: # For each server, append the server name, a colon, the state of the server, and a new line message += server + ": " + system.opc.getServerState(server) + "\n" # Show the state of the servers in a message box. system.vision.showMessage(message) ```
