system.opc.browseServer
Descriptionβ
When called from a Vision Client, Perspective Session, or the Designer, returns a list of OPCBrowseElement objects for the given server. Otherwise returns a list of PyOPCTagEx objects.
Method nodes are included in the browse results. Methods can be read and subscribed to, but not written to.
Syntaxβ
system.opc.browseServer(opcServer, nodeId)
Parametersβ
| String | opcServer | The name of the OPC server connection. |
| String | nodeId | The node ID to browse. |
Returnsβ
List - A list of PyOPCTagEx objects.
Scopeβ
Gateway
Syntax - Vision Client Scopeβ
Parametersβ
Returnsβ
List - A list of OPCBrowseElement objects.
Scopeβ
Vision Client, Perspective Session, Designer
Object Summaryβ
The OPCBrowseElement object has the following methods:
- getDisplayName() - Returns the display name of the object.
- getElementType() - Returns the element type. Element types are server, device, view, folder, object, datavariable, property and method.
- getNodeId() - Returns a string representing the server node ID. Functionally similar to getServerNodeId(), except it is available in all scopes, not just the Client/Designer.
- getDatatype() - Returns data type information.
The PyOPCTagEx object has the following methods to retrieve information:
- getServerName() - Returns the server name as a string.
- getDataType() - Returns data type information.
- New in 8.3.1getDescription() - Returns a description of the OPC tag in the specified node ID.
Code Examplesβ
Example #1
# Print the name of all devices on Ignition OPC UA
opcServer="Ignition OPC UA Server"
nodeId = "Devices"
devices = system.opc.browseServer(opcServer, nodeId)
for device in devices:
print device.getDisplayName()
Example #2
# Print the object's server node ID
# This method call works in all scopes (Client, Gateway, and Perspective)
opcServer = "Ignition OPC UA Server"
nodeId = "Devices"
results = system.opc.browseServer(opcServer, nodeId)
for result in results:
print "NodeID: ", result.getServerNodeId()
Example #3 - Recursive Browse
# This example attempts to recursively browse OPC nodes. Be mindful of the maxDepth in larger systems.
# The example uses system.util.getLogger asynchronously, so if you're calling this in the Script Console,
# the output may appear in a different console (i.e., Designer console).
from functools import partial
maxDepth = 1 # Determines how deep the browse will go
serverName = 'Ignition OPC UA Server'
myLogger = system.util.getLogger('My Browse') # Creating a logger to print the results
# Determines where the browse should start. An empty string will start at the root.
# Alternatively, '[device name]' will start at a certain device.
root = ''
def browse(nodeId, depth = 0):
children = system.opc.browseServer(serverName, nodeId)
for child in children:
elementType = str(child.getElementType())
childNodeId = child.getServerNodeId().getNodeId()
msg = 'Depth - %s, Node - %s' % (depth, childNodeId)
myLogger.info(msg)
# If the element is an object, try to browse deeper.
if (elementType == 'OBJECT' and depth < maxDepth):
browse(childNodeId, depth + 1)
system.util.invokeAsynchronous(partial(browse, root))
