system.opc.browse
Descriptionβ
Allows browsing of the OPC servers in the runtime, returning a list of tags.
This function performs a fully recursive browse that can't be terminated, which can be especially problematic in larger systems. It is highly advised to use system.opc.browseServer instead since recursion with that function is driven by subsequent calls.
Syntaxβ
This function accepts keyword arguments. :::.
system.opc.browse(opcServer, device, folderPath, opcItemPath)
Parametersβ
| String | opcServer | The name of the OPC server to browse |
| String | device | The name of the device to browse |
| String | folderPath | Filters on a folder path. Use * as a wildcard for any number of characters and a ? for a single character. |
| String | opcItemPath | Filters on a OPC item path. Use * as a wildcard for any number of characters and a ? for a single character. |
Returnsβ
List[OPCBrowseTag] - An array of OPCBrowseTag objects. OPCBrowseTag has the following functions: getOpcServer(), getOpcItemPath(), getType(), getDisplayName(), getDisplayPath(), getDataType().
Scopeβ
Code Examplesβ
# Browse every OPC server
tags = system.opc.browse()
for row in tags:
print row.getOpcServer(), row.getOpcItemPath(), row.getType(),
print row.getDisplayName(), row.getDisplayPath(), row.getDataType()
# Browse Ignition OPC UA server
tags = system.opc.browse(opcServer="Ignition OPC UA Server")
# Browse Specific Device
server = "Ignition OPC UA Server"
tags = system.opc.browse(opcServer=server, device="Dairy Demo Simulator")
# Browse Specific Folder Path (not OPC item path)
tags = system.opc.browse(opcServer=server, folderPath="*Overview/AU 1*")
