Version: 8.3
system.mongodb.insertMany
note
Project Library scripts will not provide hints for MongoDB system functions unless the Script Hint Scope is set to Gateway. See the Scripting in Ignition page for more details on scripting hints.
Inserts a list of PyDictionaries into a specified collection.
system.mongodb.insertMany(connector, collection, document, [options])
StringconnectorThe name of connector (case-insensitive).
StringcollectionThe name of collection (case-sensitive).
List[PyDictionary]documentA list of PyDictionaries that will represent new records being added to the collection. See MongoDB documentation for more details about documents.
PyDictionaryoptionsA PyDictionary for including additional insert configurations. [optional].
List[PyObject] objectIdList - Keys representing the inserted documents. The keys will usually be BSON document ObjectId, unless a different key type is specified.
Gateway, Perspective Session
Importing Classes​
You can import classes from system.mongodb.types like you would other Python classes:
Example​
from system.mongodb.types import ObjectId
newObjectId = ObjectId.get()
You can also iterate those system.mongodb.types packages to see all available classes:
Example​
for d in dir(system.mongodb.types):
print d
API Docs​
MongoDB-specific data types come from the org.bson.types package of the Mongo Java Driver API. The library of classes available for import can be accessed at this link: Mongo Java Driver 3.6.0 API Docs for Package org.bson.types.
Types References​
The following values can be referenced for the types parameter at system.mongodb.types:
Binary
Code
CodeWScope
CodeWithScope
Decimal128
INSTANCE
MaxKey
MinKey
ObjectId
Symbol
Timestamp
Example #1
# Import required BSON types.
# Specify required fields in a PyDictionary format for each BSON document in the list.
documents = [
"_id": ObjectId(),
"username": "jdoe",
"name": "Jane Doe",
"address": '123 First Street, City CA 12345',
"birthdate": system.date.getDate(2001, 4, 22),
"email": "jdoe@email.com",
"active": True,
"accounts": [],
"tier_and_details": {}
"_id": ObjectId(),
"username": "tanderson",
"name": "Thomas Anderson",
"address": '456 Seventh Street, City CA 98765',
"birthdate": system.date.getDate(1999, 3, 31),
"email": "tanderson@email.com",
"active": True,
"accounts": [],
# Apply parameters for function call.
print system.mongodb.insertMany("MongoDB", "customers", documents)
