Version: 8.3
system.mongodb.findOne
note
Project Library scripts will not provide hints for MongoDB system functions unless the Script Hint Scope is set to Gateway. See the Scripting in Ignition page for more details on scripting hints.
Returns a single PyDictionary that matches the criteria specified on the filter parameter.
system.mongodb.findOne(connector, collection, filter, [projection])
StringconnectorThe name of connector (case-insensitive).
StringcollectionThe name of collection (case-sensitive).
PyDictionaryfilterA PyDictionary for specifying matching key value pair criteria when querying a collection.
PyDictionaryprojectionA PyDictionary for including or omitting specific key value pairs in the query result. See MongoDB documentation for all valid project values. [optional]
PyDictionary result - A single PyDictionary as a result.
Gateway, Perspective Session
Importing Classes​
You can import classes from system.mongodb.types like you would other Python classes:
Example​
from system.mongodb.types import ObjectId
newObjectId = ObjectId.get()
You can also iterate those system.mongodb.types packages to see all available classes:
Example​
for d in dir(system.mongodb.types):
print d
API Docs​
MongoDB-specific data types come from the org.bson.types package of the Mongo Java Driver API. The library of classes available for import can be accessed at this link: Mongo Java Driver 3.6.0 API Docs for Package org.bson.types.
Types References​
The following values can be referenced for the types parameter at system.mongodb.types:
Binary
Code
CodeWScope
CodeWithScope
Decimal128
INSTANCE
MaxKey
MinKey
ObjectId
Symbol
Timestamp
Example #1
# Retrieve a both a connector name and collection name to query from.
connector = system.mongodb.listConnectorInfo()[0]['name']
collection = system.mongodb.listCollectionNames(connector)[0]
# Specify unique field values to locate specific document.
filter = {"qualityControlProcess":"V020"}
project = {"_id":1, "position":1,"elevation":1,"type":1}
# Apply parameters for function call.
document = system.mongodb.findOne(connector, collection, filter, project)
# Print the result. Here it is expected that all key value pairs specified in the project parameter will be available.
print "Document ID: " + str(document["_id"])
print "Type: " + str(document["type"])
print "Position: " + str(document["position"])
print "Elevation: " + str(document["elevation"])
