Version: 8.3
system.mongodb.deleteMany
note
Project Library scripts will not provide hints for MongoDB system functions unless the Script Hint Scope is set to Gateway. See the Scripting in Ignition page for more details on scripting hints.
Removes documents from the collection that match the filter.
system.mongodb.deleteMany(connector, collection, filter, [options])
StringconnectorThe name of connector (case-insensitive).
StringcollectionThe name of collection (case-sensitive).
PyDictionaryfilterA PyDictionary for specifying matching key value pair criteria when querying a collection.
PyDictionaryoptionsA PyDictionary for including additional delete configurations. [optional]
PyDictionary result - Result of delete action formatted as a PyDictionary with keys ‘acknowledged’ and ‘deleteCount’.
Gateway, Perspective Session
Example #1
# Specify unique field values to locate specific documents.
filter = {"qualityControlProcess":"V020"}
# Apply parameters for function call.
print system.mongodb.deleteMany("MongoDB", "data", filter)
