Version: 8.3
system.math.sumLog
Given a sequence of values, calculates the sum of the natural logs (ln).
Returns NaN (Not a Number) if passed an empty sequence.
system.math.sumLog(values)
List[Float]valuesA sequence of numerical values. Accepts both integers and floats. The sequence may not contain None type values. However, passing a None type object instead of a sequence of numerical values will return NaN.
Float - The sum of the natural logs of the input values, or NaN if the input was empty, None, or contains negative numbers.
Example #1
# Create a list of values.
values = [3.5, 5.6, 7.8, 7.4, 3.8]
# Print the resulting value.
print system.math.sumLog(values)
