Version: 8.3
system.math.standardDeviation
Given a sequence of numerical values, calculates the simple standard deviation. Standard deviation is a calculated number for how close, or how far the values of that dataset are in relation to the mean.
Returns NaN (Not a Number) if passed an empty sequence.
system.math.standardDeviation(values)
List[Float]valuesA sequence of numerical values. Accepts both integers and floats. The sequence may not contain None type values. However, passing a None type object instead of a sequence of numerical values will return NaN.
Float - The standard deviation of the values parameter, or NaN if the values was empty or null.
Example #1 - Calculating Standard Deviation
# Create a list of values.
values = [3.5, 5.6, 7.8, 7.4, 3.8]
# Print the resulting value.
print system.math.standardDeviation(values)
