--- title: "system.math.populationVariance" description: "Given a sequence of values, returns the population variance." --- # system.math.populationVariance > Given a sequence of values, returns the population variance. This function is used in **Python Scripting**. ## Description Given a sequence of values, returns the population variance. Population variance calculates how values in a dataset are spread out from their average value. Returns NaN (Not a Number) if passed an empty sequence. ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.math.populationVariance(values)` ### Parameters Type | Parameter | Description ------- | ------- | ------ List[Float] | `values` | A sequence of numerical values. Accepts both integers and floats. The sequence may not contain None type values. However, passing a None type object instead of a sequence of numerical values will return NaN. ### Returns **Float** - The population variance, or NaN if the input was empty or null. ### Scope Gateway, Vision Client, Perspective Session ## Code Examples ```python title="Example #1 - Calculating Population Variance" # Create a list of values. values = [3.5, 5.6, 7.8, 7.4, 3.8] # Print the resulting value. print system.math.populationVariance(values) ```
