system.math.populationVariance
Descriptionβ
Given a sequence of values, returns the population variance. Population variance calculates how values in a dataset are spread out from their average value.
Returns NaN (Not a Number) if passed an empty sequence.
Syntaxβ
system.math.populationVariance(values)
Parametersβ
| List[Float] | values | A sequence of numerical values. Accepts both integers and floats. The sequence may not contain None type values. However, passing a None type object instead of a sequence of numerical values will return NaN. |
Returnsβ
Float - The population variance, or NaN if the input was empty or null.
Scopeβ
Code Examplesβ
Example #1 - Calculating Population Variance
# Create a list of values.
values = [3.5, 5.6, 7.8, 7.4, 3.8]
# Print the resulting value.
print system.math.populationVariance(values)
