Version: 8.3
system.math.median
Takes a sequence of values, and returns the median. The median represents the middle value in a set of data.
Returns NaN (Not a Number) if passed an empty sequence.
system.math.median(values)
List[Float]valuesA sequence of numerical values. Accepts both integers and floats. The sequence may not contain None type values. However, passing a None type object instead of a sequence of numerical values will return NaN.
Float - The median, or NaN if the input was empty or null.
Example #1 - Calculating Median
# Create a list of values.
values = [3.5, 5.6, 7.8, 7.4, 3.8]
# Prints the resulting value.
print system.math.median(values)
