--- title: "system.math.geometricMean" description: "Calculates the geometric mean." --- # system.math.geometricMean > Calculates the geometric mean. This function is used in **Python Scripting**. ## Description Calculates the geometric mean. Geometric mean is a type of average which indicates a value in a set of numbers by using the product of values in the set and then taking the nth root, where *n* is the number of values in the set. This is different than an arithmetic mean, which calculates an average based off the sum of the numbers, and divides it by n number of values. Geometric means can only be positive numbers. Returns NaN (Not a Number) if passed an empty sequence. ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.math.geometricMean(values)` ### Parameters Type | Parameter | Description ------- | ------- | ------ List[Float] | `values` | A sequence of numerical values. Accepts both integers and floats. The sequence may not contain None type values. However, passing a None type object instead of a sequence of numerical values will return NaN. ### Returns **Float** - The geometric mean, or NaN if the input was empty or null. Because this uses logs to compute the geometric mean, will return NaN if any entries are negative. ### Scope Gateway, Vision Client, Perspective Session ## Code Examples ```python title="Example #1 - Calculating Geometric Mean" # Create a List of values. values = [3.5, 5.6, 7.8, 7.4, 3.8] # Prints the resulting value. print system.math.geometricMean(values) ```
