--- title: "system.kafka.sendRecordAsync" description: "Sends a record to a specified topic asynchronously." --- # system.kafka.sendRecordAsync > Sends a record to a specified topic asynchronously. This function is used in **Python Scripting**. ## Description Sends a record to a specified topic asynchronously. If a metadata response is required, [system.kafka.sendRecord](appendix\scripting-functions\system-kafka\system-kafka-sendRecord.md) can be used for blocking until a response is received. ## Client Permission Restrictions This scripting function has no [Client Permission](ignition-modules\vision\vision-project-properties\vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.kafka.sendRecordAsync(connector, topic, key, value, [partition], [timestamp], [headerKeys], [headerValues], [options])` ### Parameters | Type | Parameter | Description | |---|---|---| | String | `connector` | The name of the Kafka connector. | | String | `topic` | The name of the Kafka topic. | | String | `key` | The Kafka record key, used in identifying the record. | | String | `value` | The Kafka record value you want to send. | | Integer | `partition` | The partition to target. Optional. | | Long | `timestamp` | The record timestamp, in milliseconds. Optional. | | List | `headerKeys` | The header keys for the record. Optional. | | List | `headerValues` | The header values for the record. Optional. | | Dictionary | `options` | Custom options specific to the producer, with key value string pairs. Optional. | ### Returns Nothing ### Scope Gateway ## Code Examples ```python title="Example #1" # Sends a record to the specified topic, without any blocking. system.kafka.sendRecordAsync("MyKafkaConnector", "MyKafkaTopic", "k2", "25") ```
