--- title: "system.kafka.sendRecord" description: "Sends a record to a specified topic." --- # system.kafka.sendRecord > Sends a record to a specified topic. This function is used in **Python Scripting**. ## Description Sends a record to a specified topic, with further sends blocked until a response is received. This is considerably slower than [system.kafka.sendRecordAsync](appendix\scripting-functions\system-kafka\system-kafka-sendRecordAsync.md), and should only be used if a metadata response is required. ## Client Permission Restrictions This scripting function has no [Client Permission](ignition-modules\vision\vision-project-properties\vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.kafka.sendRecord(connector, topic, key, value, [partition], [timestamp], [headerKeys], [headerValues], [options])` ### Parameters | Type | Parameter | Description | |---|---|---| | String | `connector` | The name of the Kafka connector. | | String | `topic` | The name of the Kafka topic. | | String | `key` | The Kafka record key, used in identifying the record. | | String | `value` | The Kafka record value you want to send. | | Integer | `partition` | The partition to target. Optional. | | Long | `timestamp` | The record timestamp, in milliseconds. Optional. | | List | `headerKeys` | The header keys for the record. Optional. | | List | `headerValues` | The header values for the record. Optional. | | Dictionary | `options` | Custom options specific to the producer, with key value string pairs. Optional. | ### Returns **PyDictionary** - A PyDictionary representing metadata response in key value pairs. The metadata contains keys for: * topic * partition * offset * timestamp ### Scope Gateway ## Code Examples ```python title="Example #1" # Sends a record to the specified topic, with further sends blocked until a response is received. system.kafka.sendRecord("MyKafkaConnector", "MyKafkaTopic", "k2", "25") ```
