Version: 8.3
system.kafka.sendRecord
Sends a record to a specified topic, with further sends blocked until a response is received. This is considerably slower than system.kafka.sendRecordAsync, and should only be used if a metadata response is required.
system.kafka.sendRecord(connector, topic, key, value, [partition], [timestamp], [headerKeys], [headerValues], [options])
StringconnectorThe name of the Kafka connector.
StringtopicThe name of the Kafka topic.
StringkeyThe Kafka record key, used in identifying the record.
StringvalueThe Kafka record value you want to send.
IntegerpartitionThe partition to target. Optional.
LongtimestampThe record timestamp, in milliseconds. Optional.
ListheaderKeysThe header keys for the record. Optional.
ListheaderValuesThe header values for the record. Optional.
DictionaryoptionsCustom options specific to the producer, with key value string pairs. Optional.
PyDictionary - A PyDictionary representing metadata response in key value pairs. The metadata contains keys for:
  • topic
  • partition
  • offset
  • timestamp
Gateway
Example #1
# Sends a record to the specified topic, with further sends blocked until a response is received.
system.kafka.sendRecord("MyKafkaConnector", "MyKafkaTopic", "k2", "25")
