Version: 8.3
system.iec61850.writeFile
This function uploads a file from a local path to the configured IEC 61850 device remote path.
system.iec61850.writeFile(deviceName, localFilePath, remoteFilePath)
StringdeviceNameThe name of the configured IEC 61850 device.
StringlocalFilePathThe local file path on client to pull the file contents from.
StringremoteFilePathThe remote file path on the server of the file to write to.
No return value.
Gateway, Perspective Session
Example #1
# This example writes the file contents
# from the local temporary path to the remote file path.
device_name = 'IEC61850'
file_name = 'COMFEDE.ced'
tmp_path = '/usr/local/bin/ignition/COMFEDE/{0}'.format(file_name)
file_path = '/{0}'.format(file_name)
system.iec61850.writeFile(device_name, tmp_path, file_path)
