Version: 8.3
system.iec61850.select
Select an SBO type control to prepare it for a subsequent operate command for a configured IEC 61850 device. These selections can be removed by using the cancel function.
Select Function
The Select function is used to confirm a chosen access point before the Operate function will run. This is especially important for Select Before Operate (SBO) type controls. Misuse of this function can lead to unintended operations. Always ensure that the 'Check' parameter is properly set and understood before using this function, as it can influence the behavior of the Control Interlock (CILO) and Synchrocheck (RSYN) logical nodes in the Intelligent Electronic Device (IED).
system.iec61850.select(device_name, mapParams, value)
StringdeviceNameThe name of the configured IEC 61850 device.
PyDictionarymapParamsControl parameters dictionary that requires the following keys to be specified: name, T, orCat, orIdent, Check, and Test. If you do not know the required key value pairs, they can be found using the getControlParams function.
FloatcontrolValueControl value (32-bit float).
No return value.
Gateway, Perspective Session
Example #1
# This example prepares an SBO type control for an operate command.
mapParams = {'name': u'SSSA_52AFA_FPRCTRL/CBCSWI1.Mod', 'T':1 'orCat': 0, 'orIdent': u'not-supported', 'Check': 0, 'Test': False}
system.iec61850.select("IEC61850", mapParams, 1)
