--- title: "system.historian.storeAnnotations" description: "Store a list of annotations to the specified historian." --- # system.historian.storeAnnotations > Store a list of annotations to the specified historian. This function is used in **Python Scripting**. ## Description Stores a list of annotations to the specified historian. Annotations can be provided as individual parameter lists or as objects created with [system.historian.types.annotationPoint](appendix/scripting-functions/system-historian/types/system-historian-types-annotationPoint.md). When provided as individual parameter lists, ensure all parameters are 1:1, meaning all provided lists must be of the same length. If a particular annotation doesn't need a parameter, that element can be None in the list. ## Client Permission Restrictions This scripting function has no [Client Permission](ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax #1 `system.historian.storeAnnotations(paths, startTimes, [endTimes], [types], [data], [storageIds], [deleted])` ### Parameters |Type| Parameter| Description| |--|--|--| |List| `paths`|A list of historical paths. See [Path Syntax](appendix/scripting-functions/system-historian/system-historian.md#path-syntax) for more information on recommended syntax.| |List |`startTimes` |A list of start times associated with the annotation.| |List| `endTimes`|A list of end times associated with the annotation. [optional]| | List|`types` |A list of string types that indicate the annotation type. [optional]| |List| `data`|A list of annotation data. [optional]| |List |`storageIds` |A list of annotation storage IDs to indicate that the annotation should be updated. [optional]| |List | `deleted`|A list of deleted flags to indicate whether the annotation should be marked deleted. [optional]| ### Returns **List** - A list of [QualityCode](appendix\reference-pages\scripting-object-reference\scripting-object-reference.md#qualitycode) objects. The quality code will indicate success or failure. ### Scope Gateway, Vision Client, Perspective Session ## Syntax #2 `system.historian.storeAnnotations(annotations)` ### Parameters |Type| Parameter| Description| |--|--|--| |List| `annotations`|A list of annotations objects created with `system.historian.types.annotationPoint`.| ### Returns **List** - A list of [QualityCode](appendix\reference-pages\scripting-object-reference\scripting-object-reference.md#qualitycode) objects. The quality code will indicate success or failure. ### Scope Gateway, Vision Client, Perspective Session ## Code Examples ```python title="Syntax #1 Code Snippet" # Store an annotation on a tag and log an info level formatted message. paths = ["histprov:HistorianB:/sys:gw1:/prov:default:/tag:remote_200"] endTimes = [system.date.now()] startTimes = [system.date.addSeconds(endTimes[0], -5)] types = ['note'] data = ['this is a test'] result = system.historian.storeAnnotations(paths, startTimes, endTimes, types, data) system.util.getLogger('HistorianTest: storeAnnotations').info(str(result)) ``` ```python title="Syntax #2 Code Snippet" source = "histprov:SQL_Historian:/sys:GW1:/prov:default:/tag:test_tag" startTime = system.date.now() data = "Annotation text" annotations = [system.historian.types.annotationPoint(source=source, startTime=startTime, data=data)] system.historian.storeAnnotations(annotations) ```
