--- title: "system.historian.queryRawPoints" description: "Queries raw data points for the specified historian." --- # system.historian.queryRawPoints > Queries raw data points for the specified historian. This function is used in **Python Scripting**. ## Description Queries raw data points for the specified historian. Querying a historian involves specifying the node paths and the date range, as well as a few optional parameters. The historian will find the relevant history, then interpolate and aggregate it into a coherent, tabular result set. This function is useful when you're trying to retrieve historian data over a period of time. However, if you are trying to take a range of time and aggregate the data to a single value, consider using [system.historian.queryAggregatedPoints](system-historian-queryAggregatedPoints.md). :::note Make sure the deadband style is set to Discrete Mode if you do not want seed values included in the raw data returned. ::: ### Parameter Considerations The `returnSize` determines how the underlying data is aggregated and interpolated. If a distinct return size is specified, that will be the number of rows in the resulting dataset. You can use special numbers 0 and -1 to mean **Natural** and **On-Change**, respectively. Natural calculates a return size based on the rate of the logging historical scan classes. For example, if you query 1 hour of data for a scan class logging every minute, the natural return size is 60. On-Change means that you'll get an entry whenever any of the tags under consideration have changed. :::note Make sure the deadband style is set to Discrete Mode if you do not want seed values included in the raw data returned. ::: The span of the query can be specified using `startDate` and `endDate`. Note that intervals returned by historical queries are inclusive of the `endDate`, including when the `endDate` is set to now(). This means you may see one additional interval than expected that only contains future dates, which get interpolated to 0 and can cause trending issues. For example, if you want data from 10am - 11am in 1 minute windows, you’ll need to set your query from 10am-10:59am. Querying to 11am would create an interval to contain it and that window will often return 0 since there is typically no future value. Additionally, if you went on to add the results of two queries of adjoining times, such as 10am - 11am and 11am - 12pm, the first window of the second period would have duplicate data to the last window of the first period. ## Client Permission Restrictions This scripting function has no [Client Permission](ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.historian.queryRawPoints(paths, startTime, [endTime], [columnNames], [returnFormat], [returnSize])` ### Parameters | Type | Parameter | Description | |---|---|---| | List | `paths` | A list of historical paths to query aggregated data points for. See [Path Syntax](appendix/scripting-functions/system-historian/system-historian.md#path-syntax) for more information on recommended syntax. | | Date | `startTime` | A start time to query aggregated data points for. | | Date | `endTime` | An end time to query aggregated data points for. [Optional] | | List | `columnNames` | A list of alias column names for the returned dataset. [Optional] | | String | `returnFormat` | The desired return format for the query. [Optional] Available options include:`WIDE`: One value per path per row: [path1_val, path2_val, ..., timestamp] (default)`TALL`: One value per row: [path, value, quality, timestamp]`CALCULATION`: Calculated result per path aggregate | | Integer | `returnSize` | The maximum number of results to return. This parameter is only supported for the Internal Historian and the Core Historian. [Optional] | | Boolean | `includeBounds` | This parameter was removed in 8.3.9, but still exists in Ignition to maintain backwards compatibility. Whether to include the bounds in the query results. | | Boolean | `excludeObservations` | This parameter was removed in 8.3.9, but still exists in Ignition to maintain backwards compatibility. Whether to exclude observed aggregated data points in the query results. When applied, observed values, such as periodic samples from Tag Group evaluations will be filtered out, while source values, such as tag changes from devices will remain in the returned dataset. [Optional] | ### Returns **Dataset** - A dataset representing the raw data points for the specified historical paths. ### Scope Gateway, Vision Client, Perspective Session ## Code Examples ```python title="Code Snippet 1" # Query a specified historical simulator tag path and display raw data from within the past minute. end = system.date.now() start = system.date.addMinutes(end, -1) myDataset = system.historian.queryRawPoints(["[default]_Simulator_/Random/RandomInteger1"], start, end) for row in myDataset: print row[0], row[1] ``` ```python title="Code Snippet 2" # Query specified historian tag paths and display raw data from within the past hour # applying alias column names and return size and format configurations. results = system.historian.queryRawPoints( paths=[ "histprov:CoreHistorian:/sys:gateway:/prov:default:/tag:Folder/MyTag", "histprov:CoreHistorian:/sys:gateway:/prov:default:/tag:Folder/OtherTag" ], startTime=system.date.addHours(system.date.now(), -1), endTime=system.date.now(), columnNames=["MyTagAlias", "OtherTagAlias"], returnFormat="WIDE", returnSize=1000 ) for row in results: print results["timestamp"], results["MyTagAlias"] ```
