--- title: "system.historian.deleteAnnotations" description: "Deletes desired annotations from the specified historian." --- # system.historian.deleteAnnotations > Deletes desired annotations from the specified historian. This function is used in **Python Scripting**. ## Description ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.historian.deleteAnnotations(paths, storageIds)` ### Parameters |Type| Parameter| Description| |--|--|--| |List| `paths`|A list of historical paths associated with the annotations. See [Path Syntax](appendix/scripting-functions/system-historian/system-historian.md#path-syntax) for more information on recommended syntax.| |List|`storageIds` | A list of annotation storage IDs to be used for deleting.| ### Returns **List** - A list of [QualityCode](appendix\reference-pages\scripting-object-reference\scripting-object-reference.md#qualitycode) objects. The quality code will indicate success or failure, and if successful, the storage ID of the annotation will have been deleted. ### Scope Gateway, Vision Client, Perspective Session ## Code Examples ```python title="Code Snippet" # Delete a previously stored annotation and log an info level formatted message. paths = ["histprov:MySQL:/sys:gw1:/prov:default:/tag:history_200"] storageIds = ["1f001108-5689-4b2a-b995d360250a"] result = system.historian.deleteAnnotations(paths, storageIds) system.util.getLogger('HistorianTest: deleteAnnotations').info(str(result)) ```
