--- title: "system.historian.browse" description: "Returns a list of browse results for the specified historian." --- # system.historian.browse > Returns a list of browse results for the specified historian. This function is used in **Python Scripting**. ## Description Returns a list of browse results for the specified historian. The returned Results object can be accessed using the methods below: * getResults() will get the underlying result set. * getReturnedSize() will get the number of records in the result set. * getContinuationPoint() will get the continuation point if this function was limited, allowing you to use it in another function call to continue the browse. The result set returned from .getResults() can be iterated through with a standard for loop, and each object in the list can be accessed with the following methods: * getPath() will get the full historical tag path for that object. * getType() will get the type of the object. * hasChildren() a flag indicating whether or not the object has any children. ## Client Permission Restrictions This scripting function has no [Client Permission](ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax #1 `system.historian.browse(rootPath, [nameFilters], [maxSize], [recursive], [continuationPoint], [includeMetadata])` ### Parameters |Type| Parameter| Description| |--|--|--| |String |`rootPath` |The root path to start browsing from. See [Path Syntax](appendix/scripting-functions/system-historian/system-historian.md#path-syntax) for more information on recommended syntax. | |Date |`snapshotTime`| This parameter was removed in 8.3.9, but still exists in Ignition to maintain backwards compatibility. The snapshot time to browse at. When specified, the browse returns node definitions that were active at that historical timestamp, including tags that have since been retired. When omitted/null, the current tag structure will be returned. This parameter is only functional for the Core Historian. [optional]| |List |`nameFilters`| A list of name filters to apply to the browse results. [optional]| |Integer|`maxSize`| The maximum number of results to return. [optional]| |Boolean |`recursive`|Whether to browse recursively. Accepted values are True and False. The value is False by default, meaning that the browse will only return data directly inside the root path. When set to True, only valid leaf nodes are returned. [optional] | |String| `continuationPoint` |The continuation point to continue browsing from when browsing large result sets. The string value for this is provided in the Results object when `maxSize` limits results and more are available. This string can then be passed into a subsequent `browse()` call to retrieve the next page of results. This is similar to [`system.tag.query`](appendix/scripting-functions/system-tag/system-tag-query.md#parameters) `continuation` parameter. [optional] | |Boolean| `includeMetadata` | Whether to include metadata in the browse results. [optional]| ### Returns **Results** - A Results object that contains a list of browse results. It may only represent a partial result set, which can be determined by comparing the Total Available Size to the Returned Size. See [Scripting Object Reference](../../reference-pages/scripting-object-reference/scripting-object-reference.md#results). ### Scope Gateway, Vision Client, Perspective Session ## Syntax #2 `system.historian.browse(rootPath, BrowseFilter)` ### Parameters |Type| Parameter| Description| |--|--|--| |String| `rootPath`|The root path to start browsing from. See [Path Syntax](appendix/scripting-functions/system-historian/system-historian.md#path-syntax) for more information on recommended syntax.| |Dictionary[String, Any] |`browseFilter` | A dictionary of browse filter keys. Refer to the [Filter Keys](#filter-keys) section below for a full list of options.| #### Filter Keys The following keys represent filter criteria that can be used by the `browseFilter` parameter: * `dataType`: Represents the data type on the tag. Valid values can be found on the Tag Properties page. * `valueSource`: Represents how the node derives its value. Generally only used by nodes with a tag type of "AtomicTag". * `tagType`: The type of the node (tag, folder, UDT instance, etc). A list of possible types can be found on the Tag Properties page. * `typeId`: Represents the UDT type of the node. If the node is a UDT definition, then the value will be None. If the node is not a UDT, then this filter choice will not remove the element. As such, this filter functions best when paired with a tagType filter with a value of UdtInstance. * `quality`: Represents the "Bad" and "Good" quality on the node. All other quality codes are ignored. * `maxResults`: Limits the amount of results that will be returned by the function. ### Returns **Results** - A Results object that contains a list of browse results. It may only represent a partial result set, which can be determined by comparing the Total Available Size to the Returned Size. See [Scripting Object Reference](../../reference-pages/scripting-object-reference/scripting-object-reference.md#results). ### Scope Gateway, Vision Client, Perspective Session ## Code Examples ```python title="Syntax #1 Code Snippet" # Browse a historical simulator tag path and display the results # within the last 10 seconds, up to 10 results. rootPath = "histprov:HISTORIAN:/sys:gw1:/prov:default:/tag:FOLDER/" nameFilters = [''] maxSize = 10 recursive = False includeMetadata = True result = system.historian.browse(rootPath, maxSize, recursive, includeMetadata) system.util.getLogger('HistorianTest: browse').info(str(result)) ```
